  • JMP Security Notice: CVE-2026-109618 and CVE-2026-109619
    JMP promptly initiated a review of its products, services, and relevant infrastructure for exposure to CVE-2026-109618 and CVE-2026-109619.
    Our assessment of JMP products has not identified exposure to these vulnerabilities. Where remediation was required within supporting environments, appropriate security updates and controls have been applied and validated.
    We have identified no evidence of successful exploitation or unauthorized access to JMP systems or customer information associated with these vulnerabilities.
    JMP continues to monitor the issue and relevant vendor guidance. No action is required by JMP customers at this time.
Add wildcard options for Join
When joining data tables with Tables > Join, I often want to include all the columns from one table, while selecting only certain column from the other.  In case where the "keep all" table may have varying columns (different columns, column names), and where I want a reproducable script to do the join, it can be difficult and complex
Add an "all" wildcard option to Tables > Join.
Here is the Scripting Index exam;le for Join
Names Default To Here( 1 );
dt = Open( "$SAMPLE_DATA/Trial1.jmp" );
dt2 = Open( "$SAMPLE_DATA/Little.jmp" );
dt << Join(
	With( Data Table( "Little" ) ),
	Select( :popcorn, :oil amt, :batch, :yield ),
	SelectWith( :yield ),
	By Matching Columns( :popcorn = :popcorn, :batch = :batch, :oil amt = :oil )
I would like to do something list this
dt << Join(
	Select( all ),
Why is this idea important?
This would be for JSL coding efficiency and have the ability to joins on more general tables easily,
2 Comments
MathStatChem
Level VII
Also, yes, I do know that Query Builder can use SQL wildcards, but I don't prefer using Query Builder.  Join has a JSL simpler syntax and is in general more readable than Query Builder's JSL code.
Sarah-Sylvestre
Level V
Thank you for submitting this request and adding additional information in the comments!
