Add preference to disable JSL Debugger completely
I cannot use JSL Debugger as (I think) it has some issue with my VPN (or my VPN has issue with it). When I accidentally run debugger it will completely freeze my JMP for few minutes. I would like to have an option to completely disable JLS debugger, make it response faster with an error or maybe we could figure out why it freezes and won't work.
First error message I receive is: "A time-out encountered while attempting to connect to the JSL Debugger GUI."
4 Comments
SamGardner
Level VII
Status changed to: Needs Info
@jthi have you submitted this to JMP Technical Support?  If not, could you do so and we can look into this more closely.
jthi
No I haven't. I can do it when I get back to work next week.
jthi
Support has now been contacted, case number TS-00032103.
Also noticed that when posting/editing Wish List item in JMP Community page, it is using Tracking Number and after it has been posted it is changed to Case Number. It would be nice if these could be made same to reduce confusion.
Before posting:
After posting:
Ryan_Gilmore
Community Manager
@jthi , we'll have the field label mismatch corrected in our next update to the Community. Thanks.
