Don’t miss your chance to experience Discovery Summit Europe at our best available rate! Early bird registration through 31 Oct.
Graph Builder Toolbar streamlines interactive graphing. Creates shortcuts on Report and GraphBuilder Helpers toolbars. Download and install the extension.
This "problem" was presented today at JMP Scripting Users Group meeting Q3_2022.
Add option to extend Graph Builders legend to each page when Page is being used. I know this can be done by using By when launching Graph Builder from launcher but using Page is much much more flexible than using By especially if you have to make any changes to graph builder.
Names Default To Here(1);
dt = Open("$SAMPLE_DATA/Probe.jmp");
// Use XPatH() and Picture Box with legend
gb = dt << Graph Builder(
Show Control Panel(0),
Size(500, 9760),
Variables(X(:DELW_NEMIT), Y(:DELL_RPNBR), Page(:Wafer Number), Color(:Process)),
Elements(Points(X, Y, Legend(5)))
lg = (gb << XPath("//LegendBox"))[1];
lg_pic = lg << get picture;
fbs = (gb << XPath("//FrameBox")) << parent;
Remove From(fbs, 1); // first one already has "real" legend
//margins will need to be adjusted depending on GB size
fbs << append(Picture Box(lg_pic, << Margin(Left((gb << get size)[1]-130), Top(-15), Right(0), Bottom(0))));
// Loop over groups one by one while using Where()
nw = New Window("GBs",
lub = Lineup Box(N Col(1));
Summarize(dt, pages = by(:Wafer Number));
For Each({page}, pages,
gb_page_expr = Expr(
Eval(EvalExpr(gb = dt << Graph Builder(
Size(500, 500),
Variables(X(:DELW_NEMIT), Y(:DELL_RPNBR), Color(:Process), Group X(:Wafer Number)),
Elements(Points(X, Y, Legend(5))),
Where(:Wafer Number == Expr(page))
lub << Append(gb_page_expr);
// gb << Title("");
((lub << Top Parent) << XPath("//TextBox[contains(text(), 'Where(:')]")) << Visibility("Collapse");
// most likely best idea, use By()
gbs = Graph Builder(
Size(534, 456),
Variables(X(:DELW_NEMIT), Y(:DELL_RPNBR), Color(:Process)),
Elements(Points(X, Y, Legend(1))),
By(:Wafer Number)
Write();
