  • See how to use the JMP Marketplace – Free tools to expand JMP capabilities. Register. July 10, 2 pm US Eastern Time.
Add labels to constraints
Idea: Add a comment/label to a constraint to describe it's function
Problem: It's common to share DOE's with colleagues, when they look at how the DOE was designed it's often very difficult to know what each constraint is trying to achieve
How solution works: Labelling each constraint will indicate the intention of each constraint
1 Comment
@Donald46 - Thank you for your suggestion! We have captured your request and will take it under consideration.
