Add labels to constraints
Idea: Add a comment/label to a constraint to describe it's function
Problem: It's common to share DOE's with colleagues, when they look at how the DOE was designed it's often very difficult to know what each constraint is trying to achieve
How solution works: Labelling each constraint will indicate the intention of each constraint
1 Comment
Sarah-Sylvestre
Level V
@Donald46 - Thank you for your suggestion! We have captured your request and will take it under consideration.
