Add in ability to Tile Analysis Windows in Control Chart Builder
What inspired this wish list request? I'm looking at making a dashboard in JML Live for a bunch of control charts and I need the charts to be pretty compact so I can see all of them at once.  However, as when using split data (and it needs to be split to use different fixed control Limits ) the only option is to have a "tall" format.
What is the improvement you would like to see? I'd like to see the ability to at least be able to "Arrange in Rows" like you can in the Distribution Platform.  However, having the ability to have all the options you get when using the "By" function would be the most ideal (Layout, Hide Empty Platforms, Auto Broadcast, Order by).
Why is this idea important?  Being able to use horizontal space and vertical vs just vertical space allows for much better use of screen area to convey a lot of information in a compact space.  Critical in the world of dashboarding and BI.
7 Comments
jszarka
Level V
That sounds cool! Do you have a mock of what that would look like? Might be interesting to see what you're thinking in order to get more kudos and comments for the developers.
shampton82
Level VII
Hey @jszarka ,
This is what I am looking for (I used "Big Class" and the "By" option for CCB) but I want to be able to get this layout if the data was unstacked(vs the stacked structure in "Big "class"):
jszarka
Level V
Yes, I see that. Makes sense.
mia_stephens
Hi @shampton82 ,
How about using Process Screening?
Here's Big Class, with Age as the grouping variable (JMP 19). This is using "Charts for Selected", with the graphs resized and some options turned on.
And this is what it looks like in JMP Live:
This also works for split data.
mia_stephens
shampton82
Level VII
Hey @mia_stephens !
Let me give it a try and let you know!  Will this option also allow control chart alarming and triage like you have in Control Chart Builder?
mia_stephens
Hi Steve,
We're working on adding control chart triage functionality into Process Screening with JMP 20! @dieterpisot will be happy that you asked!
Mia
