%3CLINGO-SUB%20id%3D%22lingo-sub-329917%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3EPossibilit%C3%A0%20di%20saltare%20le%20righe%20commentate%20durante%20l'importazione%20di%20file%20di%20testo%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-329917%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3EImportiamo%20sempre%20file%20di%20testo%20che%20hanno%20un%20numero%20variabile%20di%20righe%20di%20commento%20in%20alto%20che%20iniziano%20con%20%22%23%22.%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3ESi%20prega%20di%20aggiungere%20un%20modo%20per%20JMP%20di%20ignorare%20queste%20righe%20durante%20l'importazione%20di%20file%20di%20testo%20in%20modo%20da%20non%20doverli%20pre-elaborare.%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3EAncora%20meglio%20se%20ci%20fosse%20un%20modo%20per%20leggere%20i%20nomi%20delle%20colonne%20fuori%20dalla%20riga%20che%20inizia%20con%20una%20data%20stringa%2C%20ad%20esempio%20%22%23n%22.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-329917%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CLINGO-LABEL%3EInterfaccia%20utente%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-560671%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ERe%3A%20Aggiunta%20la%20possibilit%C3%A0%20di%20saltare%20le%20righe%20commentate%20durante%20l'importazione%20di%20file%20di%20testo%20-%20Stato%20modificato%20in%3A%20Archiviato%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-560671%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3EStiamo%20archiviando%20questa%20richiesta.%20Se%20questo%20%C3%A8%20ancora%20importante%2C%20commenta%20con%20ulteriori%20dettagli%20e%20riapriremo.%20Grazie!%3C%2FLINGO-BODY%3E
Add ability to skip commented lines during text-file import
We import text files all the time that have a variable number of comment lines at the top starting with "#".
Please add a way for JMP to ignore these lines when importing text files so we don't have to pre-process them.
Even better if there were a way to read the column names out of the line that starts with a given string, e.g. "#n".
1 Comment
Ryan_Gilmore
Community Manager
Status changed to: Archived
