%3CLINGO-SUB%20id%3D%22lingo-sub-329917%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3EAgregue%20la%20capacidad%20de%20omitir%20l%C3%ADneas%20comentadas%20durante%20la%20importaci%C3%B3n%20de%20archivos%20de%20texto%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-329917%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3EImportamos%20archivos%20de%20texto%20todo%20el%20tiempo%20que%20tienen%20un%20n%C3%BAmero%20variable%20de%20l%C3%ADneas%20de%20comentarios%20en%20la%20parte%20superior%20que%20comienzan%20con%20%22%23%22.%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3EAgregue%20una%20forma%20para%20que%20JMP%20ignore%20estas%20l%C3%ADneas%20al%20importar%20archivos%20de%20texto%20para%20que%20no%20tengamos%20que%20preprocesarlos.%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3EA%C3%BAn%20mejor%20si%20hubiera%20una%20forma%20de%20leer%20los%20nombres%20de%20las%20columnas%20fuera%20de%20la%20l%C3%ADnea%20que%20comienza%20con%20una%20cadena%20determinada%2C%20por%20ejemplo%2C%20%22%23n%22.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-329917%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CLINGO-LABEL%3EInterfaz%20de%20usuario%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-560671%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ERe%3A%20Agregar%20capacidad%20para%20omitir%20l%C3%ADneas%20comentadas%20durante%20la%20importaci%C3%B3n%20de%20archivos%20de%20texto%20-%20Estado%20cambiado%20a%3A%20Archivado%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-560671%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3EEstamos%20archivando%20esta%20solicitud.%20Si%20esto%20sigue%20siendo%20importante%2C%20comente%20con%20detalles%20adicionales%20y%20volveremos%20a%20abrir.%20%C2%A1Gracias!%3C%2FLINGO-BODY%3E
Add ability to skip commented lines during text-file import
We import text files all the time that have a variable number of comment lines at the top starting with "#".
Please add a way for JMP to ignore these lines when importing text files so we don't have to pre-process them.
Even better if there were a way to read the column names out of the line that starts with a given string, e.g. "#n".
1 Comment
Ryan_Gilmore
Community Manager
Status changed to: Archived
