Add a way to open the platform which created prediction formulas with prefilled selections
Trying to make slight modifications to my existing models when I just have formula columns seems to take quite a bit of effort unless I have the script every time saved.
In most simple case I would be happy to just have a way of getting all the column names used in a formula on clipboard (also make this scriptable without clipboard...). There might be other wish list item for this item but I could quickly find one. There are solutions in the community for this but they are fairly complicated Head Arg Recurse Formula , How to automatically extract the column name used by the formula in the JSL code? .
In best case I would like to be able to re-launch the platform which did create my prediction columns. As I'm JMP Pro user, I would be fine having this as a feature in Formula Depot. In this case it would be nice if different settings would be also pre-filled IF they are stored to the column properties.
Why is this idea important?
Makes it easier to go from prediction formula back to the launcher (when possible) to make small modifications if needed or just to rerun the model with same settings without having to save the platform script every time.
4 Comments
SarahGilyard
Thank you for posting this suggestion. This request is related to a current project we are exploring that would make model building and management more efficient. This suggestion has been included for discussion.
jthi
@SarahGilyard we are currently struggling with exactly that and can most likely provide suggestions if needed. I haven't (yet) build complicated add-in for the model management but I might have to at some point (if our users get annoyed at the current way I have instructed them to do it).
jthi
This might not be directly related to this suggestion but is part of the bigger part of the problem: documenting your models. I came across this some time ago Google Model Cards, maybe JMP could have something similar (I can create separate wish list of this).
Sarah-Sylvestre
Level V
