Learn how to build custom Python data connectors and further customize JMP’s Data Connector Framework with the Python Data Connector Demo, available now in the JMP Marketplace!
See how to create experiments to support product design and ID useful product features. Register for June 12 webinar, 2pm US Eastern Time.
I've been working on this for JMP 16. I'm planning on using a technique similar to the Text Edit Box or the Button Box which have a Set Script option. Below is an example which would work in JMP 16. Let me know if you have any suggestions or concerns.
dt = Open("$SAMPLE_DATA/Process Measurements.jmp");
// Set up a Graph with a Reference line at the mean value for Process 1 on the x-axis
gb = dt << Graph Builder(
Show Control Panel(0),
Variables( X( :Process 1 ), Y( :Process 2 ) ),
Elements( Points( X, Y, Legend( 2 ) ), Smoother( X, Y, Legend( 3 ) ) ),
SendToReport(
Dispatch(
"Process 1",
ScaleBox,
{Add Ref Line( 10.0787278156801, "Dashed", "Blue", "Mean", 2 )}
// Set up a Column Switcher for Process 1
cs = gb << Column Switcher(
:Process 1,
{:Process 1, :Process 3, :Process 4, :Process 5, :Process 6, :Process 7}
// Set a Script on Process 1 which recreates the Ref Line at the new mean for the column on the X-axis.
cs << Set Script(
report = gb << Report;
col = Column(cs << Get Current());
meanX = ColMean(col);
axisbox = report[axis box( 1 )];
axisbox << Add Ref Line( meanX, "Dashed", blue, "Mean", 2 );
