    Regular business hours will resume at 9:00 a.m. ET on Friday, Jan. 2, 2026.
Add Snippets to Script Editor
If development of Script Editor will continue (and I hope it will, or hopefully JMP/SAS will create functionality/support to some other code editor) add support for code snippets. These make writing code much faster and will reduce the amount of typos. One implementation example of code snippets can be seen for example here Snippets in Visual Studio Code
8 Comments
Hi @jthi, thank you for your suggestion! We have captured your request and will take it under consideration.
jthi
I did write my own add-in to take care of this, but I cannot make it as good as I would like to have due to limitations of the tools available (or I just don't know how to access required functions).
In optimal case I would want to open menu like this and upon selection of snippet having preview either in separate window or even better in the current script
My add-in currently requires me to write "#snippet" to the script window
Then I can press the snippet shortcut Ctrl+Shift+Space to open snippet selector (search is prefilled with sql for example if user uses #snippet sql as the snippet string)
If I wanted to have sql snippet, I will first select it from the list box
and then press ok button and the #snippet will get replaced by the script seen in the snippet window
If I have enough time to work on this add-in to get it working as I want to, I think this can speed up my scripting quite a bit on repetitive tasks (and reduce mistakes) until JMP's Script Editor gets snippets.
jthi
The add-in has now been released, but I still hope JMP will provide official support to such featuresJMP Script Editor Snippets
SamGardner
Level VII
hogi
Level XIII
Cool idea - thanks for considering :)
quite useful ...
hogi
Level XIII
many thanks :)
Status changed to: Delivered
This is available in JMP 19.
