  • Due to the recently reported Microsoft outage, users may be temporarily unable to access My JMP or experience a delay receiving their verification codes. If you have previously installed JMP on your computer, this outage should not impact your ability to access the software. My JMP services will be restored as soon as Microsoft resolves this issue.
Add Profiler JSL message "<<get response values"
Right now there is a way to get the current factor settings from a profiler, but there is no native way to get the current response values from the profiler. Instead, we have to scrape them from the display tree of the profiler which could be brittle across JMP releases.
Names Default To Here( 1 );
dt = Open( "$SAMPLE_DATA/Tiretread.jmp" );
obj = dt << Profiler(
	Y( :Pred Formula ABRASION, :Pred Formula MODULUS, :Pred Formula ELONG, :Pred Formula HARDNESS ),
	Desirability Functions( 1 )
obj << Get Factor Settings;
3 Comments
SarahGilyard
Thanks for posting this suggestion to improve the profiler, andrewtkarl. We've added this suggestion to our list for future profiler improvements.
SarahGilyard
Status changed to: Delivered
The << Get Responses  option is already available. See below. Thank you for posting!
show(obj << Get Factor Settings);
show(obj<<Get Responses);
//obj << Get Responses = [139.119238722661, 1261.13313805181, 400.384575393755, 68.9096152062604];
andrewtkarl
Level IV
Thank you, Sarah. Is there also a way to get a list of the response names that those value can be paired with? I think I was having to loop over the display tree to extract those.
