JMP Security Notice: CVE-2026-109618 and CVE-2026-109619
JMP promptly initiated a review of its products, services, and relevant infrastructure for exposure to CVE-2026-109618 and CVE-2026-109619.
Our assessment of JMP products has not identified exposure to these vulnerabilities. Where remediation was required within supporting environments, appropriate security updates and controls have been applied and validated.
We have identified no evidence of successful exploitation or unauthorized access to JMP systems or customer information associated with these vulnerabilities.
JMP continues to monitor the issue and relevant vendor guidance. No action is required by JMP customers at this time.
Don’t miss your chance to experience Discovery Summit Europe at our best available rate! Early bird registration through 31 Oct.
Graph Builder Toolbar streamlines interactive graphing. Creates shortcuts on Report and GraphBuilder Helpers toolbars. Download and install the extension.
I like to use the import wizard to get Excel data into JMP (version 16.2 Pro); this works fine for files stored on LAN but I don't seem to be able to use the wizard to open files stored in Teams/SharePoint. Can this functionality please be added?
Having the ability to open files on a SharePoint site or MS Teams is essential in most companies now with remote working, having a script to open a file isn't really acceptable. I would hope this would be included in JMP soon
I agree. This is a need that JMP doesn't cover. Users need to download the file first and do a one-time analysis. In the end, PowerBI is used instead as it is fully integrated.
For this, not only accessing but being able to update the JMP table once loaded, will also be needed.
@GemmaBarnes We have prioritized this request and hope to have it implemented in a future version of JMP (likely JMP 19). I will update this request with more details when we start working on this.
Additional note: although we plan to implement an easier way for you to access Sharepoint files, it may not be implemented the way you describe in your wish (through the import wizard). It will likely be similar to how you can access Google Sheets files in JMP currently, but we are not sure what the UI will be right now. Let me know if you have any questions!
