JMP Tips
Remove Entries from a Hover Label
Remove unwanted entries from a hover label using the Hover Label Editor.
  1. In a JMP graph, right-click on a hover label and select Edit.
  2. Edit a Hover LabelEdit a Hover Label
  3. In the Hover Label Editor, click the data that you want to remove (in this case, name).
  4. Select Data to RemoveSelect Data to Remove
  5. In the Delete tab, the selected data appears under Target. Click Add.
    In this case, this adds "name" under Entries (for deletion).
  6. Click OK.
  7. Data Removed from Hover LabelData Removed from Hover Label
    The data no longer appears in the hover labels.
For more information, see the hover labels section in the JMP Online Help.
