  • Register to see how to import and prepare Excel data on Jan. 30 from 2 to 3 p.m. ET.
Learning Library
Quickly Import Data
Use a wizard to quickly import data from the web, Excel, a PDF, and more.
  1. Select View (Windows) or Window (macOS) > JMP Starter.
  2. Click Import.
  3. Depending on the type of data or where you want to import it from, choose a wizard.
  4. Follow the steps in the wizard to import your data.
Import Data from the JMP StarterImport Data from the JMP Starter
