historicalDate.jsl
Edit
//*****************************************************FUNCTION*****************************************************************//
// Title: returnhistoricalDate //
// Description: return date x years //
// Inputs: numYears //
// Output: Date - x years //
// class: date //
// version 1.0 //
// developed by: alex.cook0 //
Comments
txnelson
The function makes the assumption of a consistant number of seconds in every year.  This is not a true assumption.  Running the function and asking for the date 400 years ago
x=returnhistoricaldate(400);
returns the date of 01Mar1616
The below statement returns the correct date
y=as date(date mdy(month(today()),day(today()),Year(today())-400));
Jim,
As a quick development, making the assumption for data stored within the last 20 years would be fine.
I wrote this without the need to go back 400 years.
You are technically correct but for the purposes of this proof of concept 100% accuracy was not needed.
The script could be modified to use your idea described above.
Many Thanks.
