  • See how to use Accelerated Life Testing (ALT) to evaluate reliability. Register for June 5 webinar, 2pm US Eastern Time.
Sqlite3 to JMP Data table through Python Integration
The attached JSL uses JMP's Python integration to create a sqlite3 database file by recursively descending a directory of files.  The directory is chosen using JSL's Pick Directory().  The path is passed through to the Python environment.
A MD5 checksum is computed for each file and that along with the path is inserted into the sqlite3 database, then the sqlite3 table is imported into JMP as a Data Table.
Screen Shot 2021-03-09 at 4.14.29 PM.pngRe-running the script just appends another directory's worth of information into the database.  Also demonstrated is an example of fully specifying dll and sys.path in the Python Init().
Comments
This sample has been updated as a Python script in JMP 18.0's SAMPLE_SCRIPTS/Python/ directory as pyDigest.py.  It provides the same functionality as this JSL script but implemented to take advantage of the JMP 18 Python integration capabilities.  Including creating a data table in Python and populating the columns from the SQL query's result set in Python.
