  • Register to see how to import and prepare Excel data on Jan. 30 from 2 to 3 p.m. ET.
Column Formulas to CSV
Craige_Hales
JSL to find the formulas in a JMP data table and write a CSV (comma separated value) file.  There is an open issue for exporting formulas to Excel; maybe this script can serve as a starting point to determine what is really needed.
The code also demonstrates a simple use of Regex, user functions, and saving a file to the $TEMP directory.
This code has only been tested on the included data table.
which opens this table
which the attached JSL exports to this CSV text
If the .CSV file is opened in Excel, the formulas are character fields.
Comments
Another option is to add a row to the table where any column formulas could be appended.
The following example loops through each column to check for a formula.  If a formula is found, the formula is added to the last row.  Finally, the table is stored as CSV or Excel.
dt = Open( "$SAMPLE_DATA\Tiretread.jmp" );
dt << Run Formulas;
dt << Add Rows( 1 );
r = N Rows( dt );
For( i = 1, i <= N Cols( dt ), i++,
	f = Column( i ) << Get formula;
	If( !Is Empty( f ),
		Column( i ) << Delete Formula;
		Column( i ) << Data Type( "Character" );
		Column( i )[r] = Char( Name Expr( f ) );
dt << Save( "$TEMP\Tiretread_Formulas.xlsx" );
dt << Save( "$TEMP\Tiretread_Formulas.csv" );
Close( dt, "No Save" );
Is this helpful for exporting JMP column formulas to Excel?
Much better approach, thanks!  You've used JMP's builtin functions to do a lot of the stuff I did the hard way.
