JMP Scripting: The great Morpheus once said, " Unfortunately, no one can be told what the Matrix is. You have to see it for yourself." Join JMP SE Jason Wiggins to see the Matrix and the ways it can help you write more efficient code.
Sep 24, 2024 02:58 PM(2118 views)
Announcing new meeting date and topic for Nov. 22nd.
Re: JMP Scripting: The great Morpheus once said, " Unfortunately, no one can be told what the Matrix is. You have to see it for yourself." Join JMP SE Jason Wiggins to see the Matrix and the ways it can help you write more efficient code.
