Huge thanks for posting those!
Its nice to stay current.
Hey @MikeD_Anderson I second Byron_JMP! (many thanks)
Any chance you can post the 2023 (or most current) when you get a chance? These end up being handy quite often.
@PatrickGiuliano, & @Byron_JMP - updated with the 2022 files. Looks like they don't update them until later in Q3, so that's the latest.
How do you use these two files? I read the documentation on Map Shapes, but I don't understand it. If I wanted to draw all of the zip code regions on a map and color them by their zip code value, is that possible with this dataset?
Hi @BHarris ,you just have to link the ZIP codes in your table to the IDs in the reference table:
new table ("zips", add rows(100000),New Column( "zip",
Character,
"Nominal",
Set Property(
"Map Role",
Map Role( Shape Name Use( "C:\TEMP\US_ZIP5_2022-Name.jmp", "ZIP_CODE" ) )
Formula (Right(Char(row()),5,"0")
Graph Builder(
Summary Statistic( "Median" ),
Graph Spacing( 4 ),
Variables( Shape( :zip ) ),
Elements( Map Shapes( Legend( 2 ) ) )
Thanks, I had been trying to set the map role of the Shape column in the "-Name" file over to the Shape column in the "-XY" file.
If there is good documentation for how this works, I haven't been able to find it.
I just checked if LearnBot knows the answer:
the cited file:One Page Guide - 02-mapping-in-graph-builder.pdf
... and found a link to
