キャンセル
次の結果を表示
表示  限定  | 次の代わりに検索
もしかして:
2022 US 5 Digit Zipcode Shapefiles
2022 2020 Shapefiles for US 5 Digit Zipcodes pulled from US Census Gazetteer.
04May2023 - updated with the 2022 shape files
コメント
Craige_Hales
links to interesting information; zip codes as defined by the post office are routes for a letter carrier, not areas, and may not be exactly what you imagine. The census folks make the Zip Code Tabulation Areas (ZCTA), somehow, from the routes.
Byron_JMP
Huge thanks for posting those!
Its nice to stay current.
PatrickGiuliano
Hey @MikeD_Anderson I second ! (many thanks)
Any chance you can post the 2023 (or most current) when you get a chance? These end up being handy quite often.
MikeD_Anderson
@PatrickGiuliano, & @Byron_JMP  - updated with the 2022 files.  Looks like they don't update them until later in Q3, so that's the latest.
PatrickGiuliano
Fantastic, thank you @MikeD_Anderson!
BHarris
How do you use these two files?  I read the documentation on Map Shapes, but I don't understand it.  If I wanted to draw all of the zip code regions on a map and color them by their zip code value, is that possible with this dataset?
hogi
Hi @BHarris ,you just have to link the ZIP codes in your table to the IDs in the reference table:
new table ("zips", add rows(100000),New Column( "zip",
	Character,
	"Nominal",
	Set Property(
		"Map Role",
		Map Role( Shape Name Use( "C:\TEMP\US_ZIP5_2022-Name.jmp", "ZIP_CODE" ) )
	Formula (Right(Char(row()),5,"0")
Graph Builder(
	Summary Statistic( "Median" ),
	Graph Spacing( 4 ),
	Variables( Shape( :zip ) ),
	Elements( Map Shapes( Legend( 2 ) ) )
BHarris
Thanks, I had been trying to set the map role of the Shape column in the "-Name" file over to the Shape column in the "-XY" file.
If there is good documentation for how this works, I haven't been able to find it.
hogi
I just checked if LearnBot knows the answer:
the cited file:One Page Guide - 02-mapping-in-graph-builder.pdf
... and found a link to
[English+Documentation]
おすすめの記事
