JMP Knowledge Base
Unable to authorize JMP 19 Student Edition on MacOS
Issue
Upon initial launch of JMP 19 Student Edition, user authorization is required.
After entering your email address and the verification code, JMP may close.
Subsequent launches of the program result in the same issue: JMP closes and is not authorized.
This is a known issue for JMP 19 Student Edition on MacOS only. A folder required for authorization is created with incorrect permissions.
Resolution
To resolve this issue, follow these steps:
Step 1: Download the JMP Student Edition Repair tool.
Step 2: Unzip and launch the tool, and then click Proceed.
Step 3: Enter administrative credentials for MacOS and click OK.
Step 4: Click OK to confirm completion.
Step 5: Uninstall JMP 19.0 Student Edition by moving the application to the Trash.
Step 6: Download and install JMP 19.0.1 Student Edition from my.jmp.com.
If you experience any issues or need assistance, contact JMP Technical Support.
Comments
what about for JMP 18
Details
Products JMP
