JMP Knowledge Base
The Rename Directory() function might fail to rename directories on network drives
Using the Rename Directory() function to change the name of a file system directory might return 0 when you attempt to rename a directory that is found on a network drive.
To work around the issue, use the Move Directory() function, which can work for both local and network drives.  Here is an example:
rc1 = Move Directory( "$TEMP/Loss Function Templates", "$TEMP/subB" );
[Previously JMP Note 68195]
Details
Operating System
macOS Windows
Reported Version
16.0
Fixed Version
16.2
Products JMP JMP Pro
