  • Register to attend Discovery Summit 2025 Online: Early Users Edition, Sept. 24-25.
  • New JMP features coming to desktops everywhere this September. Sign up to learn more at jmp.com/launch.
Manual Authorization of JMP®
The following guide can be used to authorize JMP 18.1 and newer on non-networked (airgapped) machines. The most recent version of JMP can be downloaded from my.jmp.com
Step 1) Launch JMP
Step 2) Copy the entire Request Code from the Authorization screen:
Step 3) Navigate to jmp.com/authorize on a networked machine
You are prompted for an email address. This email address must be authorized for JMP usage.
After signing in, you will receive a verification code via email.
Step 4) Enter the Request Code from JMP and click “Get Authorization Code”
Step 5) Click “Download as File” or “Send in Email” to obtain your Response Code.txt file
Step 6) Go back to JMP and click the Browse button on the Authorization screen and navigate to the Response Code.txt file. Select it to complete manual authorization of JMP 18.
Comments
Hi,
thanks for this guide.
But how do i preconfigure a proxy before the first run of JMP for other users?
I'm creating a preconfigured deploy package in our environment and JMP thinks its on an airgapped machine. But actually its behind a proxy.
(JMP Pro 18.0.2 Student Edition on MacOS and Windows 11)
Thank you
@PerceptualPuma5 - I'm not sure I understand your question. Please contact JMP Tech Support, support@jmp.com to clarify the situation and get an answer. Thanks!
Details
Products JMP JMP Pro JMP Live JMP Clinical
