Browse apps to extend the software in the new JMP Marketplace
18.1 Installer: Modify and Repair options break JMP's Python integration
Background
Updating JMP 18 will break the Python Integration using Repair or Modify to install. Repair and Modify do not properly install the DLLs (Python files) folder needed to run the Python integration in JMP 18.
Solution
Uninstall JMP 18 from your machine. Re-install the JMP 18 update (e.g., 18.1). Doing so will avoid the "Modify, repair, or remove the program" dialog.
These steps will properly install the DLLs needed to run the Python integration.
Comments
hogi
With JMP18.1 installed, is there any possiblity to add the dlls?
.. besides uninstalling and installing it again?
jthi
Maybe with these instructions Re: Issue installing sklearn python package with jpip - JMP User Community but I would just uninstall and install to avoid any possible issues (and that is what I did when I learned about this issue).
hogi
Ah, Ok.
then better check the DDL folder before deleting JMP. Maybe it's not necessary to delete it.
Details
Operating System
Windows
Products JMP JMP Pro JMP Clinical
