JMP Blog
%3CLINGO-SUB%20id%3D%22lingo-sub-61889%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%20mode%3D%22NONE%22%20mode%3D%22NONE%22%3ERe%3A%20Parcelas%20vectoriales%20en%20JMP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-61889%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%20mode%3D%22NONE%22%20mode%3D%22NONE%22%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-53675%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%20mode%3D%22NONE%22%20mode%3D%22NONE%22%3ERe%3A%20Parcelas%20vectoriales%20en%20JMP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-53675%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%20mode%3D%22NONE%22%20mode%3D%22NONE%22%3E%3CP%3EHola%20xan%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3EMe%20preguntaba%20si%20puede%20sugerir%20una%20manera%20eficiente%20de%20aplicar%20las%20flechas%20a%20m%C3%BAltiples%20gr%C3%A1ficos%20de%20ajuste%20bivariados%20(agrupados%20por%20alguna%20otra%20columna).%26nbsp%3B%20Por%20ejemplo%2C%20si%20tuviera%20varios%20d%C3%ADas%20de%20datos%20de%20'ChicagoWind'%20y%20quisiera%20trazar%20varios%20gr%C3%A1ficos%20bivariados%20para%20cada%20fecha%20y%20aplicar%20las%20flechas%20por%20fecha.%26nbsp%3B%20%C2%BFHay%20una%20forma%20m%C3%A1s%20f%C3%A1cil%20de%20hacer%20esto%20en%20lugar%20de%20crear%20un%20bucle%20para%20cada%20fecha%3F%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3EGracias%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3ERy%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-31482%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%20mode%3D%22NONE%22%20mode%3D%22NONE%22%3EXan%20Gregg%20escribi%C3%B3%3A%20Por%20supuesto%20que%20puedes%20hacer%20cualquier%20cosa%20modificando%20...%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-31482%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%20mode%3D%22NONE%22%20mode%3D%22NONE%22%3E%3CP%3E%3CSTRONG%3E%20Xan%20Gregg%20%3C%2FSTRONG%3E%20escribi%C3%B3%3A%3C%2FP%3E%3CP%3EPor%20supuesto%20que%20puedes%20hacer%20cualquier%20cosa%20modificando%20el%20script%20%3A).%20Por%20ejemplo%2C%20para%20operar%20en%20una%20sola%20columna%20x%20e%20y%2C%20reemplace%20el%20comando%20Flecha%20con%20algo%20como%20If%20(fila%20()%26gt%3B%201%2C%20Flecha%20(%7Bx%20%5Bfila%20()%20-%201%5D%2C%20y%20%5Bfila%20()%20-%201%5D%7D%2C%20%7B%20x%2C%20y%7D)).%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EIncluso%20sin%20modificar%20el%20script%2C%20puede%20obtener%20el%20efecto%20encadenando%20los%20valores%20x%20%2F%20y%20en%20la%20tabla.%20Es%20decir%2C%20x1%2C%20y1%20de%20la%20fila%20n%20ser%C3%ADa%20lo%20mismo%20que%20x2%2C%20y2%20de%20la%20fila%20n-1.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-31481%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%20mode%3D%22NONE%22%20mode%3D%22NONE%22%3EDaryl%20Purcell%20escribi%C3%B3%3A%20%C2%BFEs%20posible%20dibujar%20%2F%20anexar%20una%20l%C3%ADnea%20...%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-31481%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%20mode%3D%22NONE%22%20mode%3D%22NONE%22%3E%3CP%3E%3CSTRONG%3E%20Daryl%20Purcell%20%3C%2FSTRONG%3E%20escribi%C3%B3%3A%3C%2FP%3E%3CP%3E%C2%BFEs%20posible%20dibujar%20%2F%20anexar%20una%20l%C3%ADnea%20desde%20la%20punta%20de%20un%20vector%20a%20otro%3F%20ser%C3%ADa%20muy%20%C3%BAtil%20en%20aplicaciones%20de%20an%C3%A1lisis%20residual%20donde%20el%20usuario%20est%C3%A1%20interesado%20en%20la%20forma.%20H%C3%A1zmelo%20saber.%20%C2%A1Gracias!%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-31480%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%20mode%3D%22NONE%22%20mode%3D%22NONE%22%3EXan%20Gregg%20escribi%C3%B3%3A%20%C2%BFAgregaste%20el%20script%20personalizado%3F%20Eso%20es%20wh%20...%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-31480%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%20mode%3D%22NONE%22%20mode%3D%22NONE%22%3E%3CP%3E%3CSTRONG%3E%20Xan%20Gregg%20%3C%2FSTRONG%3E%20escribi%C3%B3%3A%3C%2FP%3E%3CP%3E%C2%BFAgregaste%20el%20script%20personalizado%3F%20Eso%20es%20lo%20que%20tira%20en%20Lat2%20y%20Lon2.%20Puede%20probar%20el%20gui%C3%B3n%20del%20comentario%20de%20Karen%20anterior%20para%20obtener%20una%20soluci%C3%B3n%20completa%2C%20y%20luego%20trabajar%20hacia%20atr%C3%A1s%20para%20ver%20en%20qu%C3%A9%20se%20diferencia%20del%20suyo.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-31479%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%20mode%3D%22NONE%22%20mode%3D%22NONE%22%3ENishant%20Thakur%20escribi%C3%B3%3A%20Hola%2C%20soy%20Nishant.%20Estoy%20intentando%20esto%20...%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-31479%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%20mode%3D%22NONE%22%20mode%3D%22NONE%22%3E%3CP%3E%3CSTRONG%3E%20Nishant%20Thakur%20%3C%2FSTRONG%3E%20escribi%C3%B3%3A%3C%2FP%3E%3CP%3EHola%2C%20soy%20Nishant.%20Estoy%20probando%20este%20script%20pero%20solo%20Lat1%20y%20Lon1%20se%20pueden%20trazar%20en%20el%20gr%C3%A1fico.%20%C2%BFC%C3%B3mo%20debo%20trazar%20Lat2%20y%20Lon2%20en%20el%20mismo%20gr%C3%A1fico.%20%C2%BFPodr%C3%ADas%20por%20favor%20guiarme%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-31478%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%20mode%3D%22NONE%22%20mode%3D%22NONE%22%3EKaren%20escribi%C3%B3%3A%20Hola%20Xan%2C%20%C2%BFPuedo%20obtener%20una%20copia%20de%20tu%20vectorplot%20...%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-31478%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%20mode%3D%22NONE%22%20mode%3D%22NONE%22%3E%3CP%3E%3CSTRONG%3E%20Karen%20%3C%2FSTRONG%3E%20escribi%C3%B3%3A%3C%2FP%3E%3CP%3E%20%20%20%20Hola%20xan%3C%2FP%3E%3CP%3E%C2%BFPuedo%20obtener%20una%20copia%20de%20su%20tabla%20de%20vectorplot%20con%20script%3F%20Me%20gustar%C3%ADa%20entender%20mejor%20esta%20capacidad.%3C%2FP%3E%3CP%3EGracias%2C%3C%2FP%3E%3CP%3EKaren%20%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-31477%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%20mode%3D%22NONE%22%20mode%3D%22NONE%22%3EXan%20Gregg%20escribi%C3%B3%3A%20Sub%C3%AD%20el%20archivo%20de%20datos%20al%20archivo%20Exc%20...%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-31477%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%20mode%3D%22NONE%22%20mode%3D%22NONE%22%3E%3CP%3E%3CSTRONG%3E%20Xan%20Gregg%20%3C%2FSTRONG%3E%20escribi%C3%B3%3A%3C%2FP%3E%3CP%3E%20%20%20%20Sub%C3%AD%20el%20archivo%20de%20datos%20al%20Intercambio%20de%20archivos%20con%20el%20nombre%20%22ChicagoWind.jmp%22.%20Incluye%20scripts%20que%20dibujan%20la%20trama%20con%20vectores.%20%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-31476%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%20mode%3D%22NONE%22%20mode%3D%22NONE%22%3EKaren%20escribi%C3%B3%3A%20Gracias%20Xan%2C%20muy%20interesante%20y%20f%C3%A1cil%20de%20seguir%20...%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-31476%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%20mode%3D%22NONE%22%20mode%3D%22NONE%22%3E%3CP%3E%3CSTRONG%3E%20Karen%20%3C%2FSTRONG%3E%20escribi%C3%B3%3A%3C%2FP%3E%0A%3CP%3EGracias%20xan%3C%2FP%3E%0A%3CP%3EMuy%20interesante%20y%20f%C3%A1cil%20de%20seguir.%20No%20sab%C3%ADa%20que%20pudieras%20agregar%20una%20secuencia%20de%20comandos%20a%20un%20gr%C3%A1fico%20como%20ese.%20Jugu%C3%A9%20con%20los%20ejemplos%20y%20agregu%C3%A9%20la%20l%C3%ADnea%20de%20color%20del%20l%C3%A1piz%20para%20que%20la%20flecha%20ahora%20tome%20su%20color%20de%20la%20tabla.%20Luego%20agregu%C3%A9%20una%20leyenda%20al%20gr%C3%A1fico%20para%20que%20coloree%20las%20filas%20seg%C3%BAn%20la%20temperatura%20y%20termines%20con%20flechas%20y%20puntos%20de%20colores%20bonitos.%3C%2FP%3E%0A%3CP%3E%C2%BFC%C3%B3mo%20se%20obtiene%20la%20imagen%20en%20segundo%20plano%20en%20la%20captura%20de%20pantalla%20de%20tu%20blog%3F%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CPRE%3E%3CCODE%20class%3D%22%20language-jsl%22%3EBivariate(%0AY(%20%3ALat1%20)%2C%0AX(%20%3ALon1%20)%2C%0ASendToReport(%0ADispatch(%0A%7B%7D%2C%0A%22Bivar%20Plot%22%2C%0AFrameBox%2C%0A%7BFrame%20Size(%20501%2C%20429%20)%2C%0AAdd%20Graphics%20Script(%0A2%2C%0ADescription(%20%22Script%22%20)%2C%0AFor%20Each%20Row(%0APen%20Color(%20Color%20Of(%20Row%20State()%20)%20)%3B%0APen%20Size(%202%20)%3B%0AArrow(%20%7B%3ALon1%2C%20%3ALat1%7D%2C%20%7B%3ALon2%2C%20%3ALat2%7D%20)%3B%0A)%0A)%2C%20Row%20Legend(%0ATMPF%2C%0AColor(%201%20)%2C%0AColor%20Theme(%20%22Blue%20to%20Gray%20to%20Red%22%20)%2C%0AMarker(%200%20)%2C%0AMarker%20Theme(%20%22%22%20)%2C%0AContinuous%20Scale(%201%20)%2C%0AReverse%20Scale(%200%20)%2C%0AExcluded%20Rows(%200%20)%0A)%7D%0A)%0A)%0A)%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-31475%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%20mode%3D%22NONE%22%20mode%3D%22NONE%22%3EXan%20Gregg%20escribi%C3%B3%3A%20Muy%20bonito%2C%20eso%20da%20cinco%20dimensiones%20...%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-31475%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%20mode%3D%22NONE%22%20mode%3D%22NONE%22%3E%3CP%3E%3CSTRONG%3E%20Xan%20Gregg%20%3C%2FSTRONG%3E%20escribi%C3%B3%3A%3C%2FP%3E%3CP%3E%20%20%20%20Muy%20bonito%20-%20eso%20da%20cinco%20dimensiones%20de%20datos%2C%20ahora.%3C%2FP%3E%3CP%3ELa%20imagen%20de%20fondo%20se%20discute%20un%20poco%20en%20la%20publicaci%C3%B3n%20del%20blog.%20Arrastr%C3%A9%20un%20archivo%20PNG%20manualmente%3B%20desafortunadamente%2C%20no%20es%20actualmente%20programable.%20%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-31474%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%20mode%3D%22NONE%22%20mode%3D%22NONE%22%3EDaveG%20escribi%C3%B3%3A%20hola%2C%20nota%20para%20los%20lectores%3A%20en%20JMP%209%20puedes%20tomar%20...%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-31474%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%20mode%3D%22NONE%22%20mode%3D%22NONE%22%3E%3CP%3E%3CSTRONG%3E%20DaveG%20%3C%2FSTRONG%3E%20escribi%C3%B3%3A%3C%2FP%3E%3CP%3E%20%20%20%20Hola%2C%3C%2FP%3E%3CP%3Enota%20para%20los%20lectores%3A%20en%20JMP%209%20puede%20tomar%20este%20script%20y%20agregar%20un%20mapa%20de%20EE.%20UU.%20de%20fondo.%20Haga%20clic%20con%20el%20bot%C3%B3n%20derecho%20en%20el%20gr%C3%A1fico%20para%20personalizarlo%20y%20seleccione%20el%20mapa%20de%20estados%20de%20EE.%3C%2FP%3E%3CP%3E%C2%A1Genial!%3C%2FP%3E%3CP%3EDave%20%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-29776%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%20mode%3D%22NONE%22%20mode%3D%22NONE%22%3EParcelas%20vectoriales%20en%20JMP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-29776%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%20mode%3D%22NONE%22%20mode%3D%22NONE%22%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3ELas%20gr%C3%A1ficas%20vectoriales%20muestran%20flechas%20en%20una%20gr%C3%A1fica%20bidimensional%20y%20permiten%20ver%20cuatro%20dimensiones%20de%20datos%3A%20posici%C3%B3n%20x%2C%20posici%C3%B3n%20y%2C%20%C3%A1ngulo%20de%20flecha%20y%20longitud%20de%20flecha.%20De%20manera%20equivalente%2C%20las%20cuatro%20dimensiones%20pueden%20ser%20x%20posici%C3%B3n%20inicial%2C%20y%20posici%C3%B3n%20inicial%2C%20x%20posici%C3%B3n%20final%2C%20y%20posici%C3%B3n%20final%20y.%20La%20%C3%BAltima%20forma%20es%20m%C3%A1s%20conveniente%20para%20JMP.%20Aunque%20JMP%20no%20tiene%20un%20comando%20de%20men%C3%BA%20para%20crear%20gr%C3%A1ficos%20vectoriales%2C%20las%20flechas%20se%20pueden%20agregar%20a%20casi%20cualquier%20gr%C3%A1fico%20sin%20muchos%20problemas.%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3ESi%20bien%20se%20pueden%20adaptar%20muchos%20conjuntos%20de%20datos%20de%20cuatro%20variables%20para%20la%20visualizaci%C3%B3n%20de%20vectores%2C%20lo%20demostrar%C3%A9%20con%20una%20de%20las%20aplicaciones%20m%C3%A1s%20naturales%3A%20los%20datos%20de%20viento.%20Este%20conjunto%20de%20datos%20registra%20la%20velocidad%20y%20direcci%C3%B3n%20del%20viento%20para%20varias%20estaciones%20meteorol%C3%B3gicas%20en%20el%20%C3%A1rea%20de%20Chicago.%20Utilic%C3%A9%20f%C3%B3rmulas%20para%20convertir%20la%20velocidad%20y%20la%20direcci%C3%B3n%20en%20posiciones%20finales%20para%20las%20flechas%20y%20luego%20agregu%C3%A9%20el%20siguiente%20gui%C3%B3n%20de%20gr%C3%A1ficos%20a%20un%20diagrama%20de%20dispersi%C3%B3n%20bivariable%20utilizando%20Personalizar%20en%20el%20men%C3%BA%20de%20clic%20derecho%20del%20gr%C3%A1fico.%3C%2FP%3E%0A%3CP%3E%3C%2FP%3E%3CDIV%20class%3D%22lia-vid-container%20video-embed-center%20lia-video-unavailable%22%3E%3CDIV%20id%3D%22lia-vid-ViMG9paDE6wbLG6-syrMetKy_VXJiMlUw400h300r390%22%20class%3D%22lia-video-ooyala-player-container%22%3E%3CDIV%20class%3D%22lia-video-status-message%22%3EEste%20video%20est%C3%A1%20siendo%20procesado%20actualmente.%20Por%20favor%2C%20int%C3%A9ntalo%20de%20nuevo%20en%20unos%20minutos.%3C%2FDIV%3E%3C%2FDIV%3E%3CA%20class%3D%22video-embed-link%22%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fvideo%2Fgallerypage%2Fvideo-id%2FViMG9paDE6wbLG6-syrMetKy_VXJiMlU%22%20target%3D%22_blank%22%3E(ver%20en%20Mis%20videos)%3C%2FA%3E%3C%2FDIV%3E%3CP%3E%3C%2FP%3E%0A%3CPRE%3E%3CCODE%20class%3D%22%20language-jsl%22%3EBivariate(%0A%20Y(%20%3ALat1%20)%2C%0A%20X(%20%3ALon1%20)%2C%0A%20Show%20Points(%200%20)%2C%0A%20SendToReport(%0A%20%20Dispatch(%20%7B%7D%2C%20%221%22%2C%20ScaleBox%2C%20%7BMin(%20-90.9505699180481%20)%7D%20)%2C%0A%20%20Dispatch(%20%7B%7D%2C%20%222%22%2C%20ScaleBox%2C%20%7BMin(%2038.9936726055607%20)%2C%20Max(%2044.9620694317012%20)%2C%20Minor%20Ticks(%200%20)%7D%20)%2C%0A%20%20Dispatch(%0A%20%20%20%7B%7D%2C%0A%20%20%20%22Bivar%20Plot%22%2C%0A%20%20%20FrameBox%2C%0A%20%20%20%7BFrame%20Size(%20501%2C%20429%20)%2C%20Add%20Graphics%20Script(%0A%20%20%20%201%2C%0A%20%20%20%20Description(%20%22Script%22%20)%2C%0A%20%20%20%20Pen%20Size(%202%20)%3B%0A%20%20%20%20For%20Each%20Row(%20Arrow(%20%7Blon1%2C%20lat1%7D%2C%20%7Blon2%2C%20lat2%7D%20)%20)%3B%0A%20%20%20)%2C%20Grid%20Line%20Order(%203%20)%2C%20Reference%20Line%20Order(%202%20)%7D%0A%20%20)%0A%20)%0A)%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%3EAqu%C3%AD%20hay%20una%20captura%20de%20pantalla%20que%20muestra%20un%20poco%20de%20la%20tabla%20de%20datos%2C%20el%20gr%C3%A1fico%20y%20el%20cuadro%20de%20di%C3%A1logo%20personalizado%3A%20%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-center%22%20style%3D%22width%3A%20474px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Windcapture%22%20style%3D%22width%3A%20474px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Windcapture%22%20style%3D%22width%3A%20474px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Windcapture%22%20style%3D%22width%3A%20474px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F16648iF898CF4197AD861A%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22windcapture.jpeg%22%20alt%3D%22Windcapture%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EWindcapture%3C%2Fspan%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EWindcapture%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EWindcapture%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E%20Captura%20de%20viento%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3ELos%20siguientes%20pasos%20fueron%20eliminar%20las%20filas%20sin%20viento%20y%20desactivar%20los%20puntos%20en%20el%20gr%C3%A1fico.%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EPara%20proporcionar%20contexto%2C%20agregu%C3%A9%20el%20mapa%20de%20estaciones%20meteorol%C3%B3gicas%20provisto%20por%20el%20servicio%20meteorol%C3%B3gico.%20Colocar%20una%20imagen%20en%20un%20gr%C3%A1fico%20es%20un%20poco%20complicado%20(y%20podr%C3%ADa%20ser%20el%20tema%20de%20otra%20publicaci%C3%B3n).%20Hay%20dos%20opciones%3A%20dibujar%20la%20imagen%20en%20otro%20script%20de%20gr%C3%A1ficos%20personalizados%2C%20o%20arrastrar%20y%20soltar%20una%20imagen%20existente%20en%20el%20gr%C3%A1fico.%20Eleg%C3%AD%20este%20%C3%BAltimo%20ya%20que%20ten%C3%ADa%20un%20archivo%20de%20imagen.%20Primero%2C%20dimension%C3%A9%20el%20gr%C3%A1fico%20para%20que%20fuera%20del%20mismo%20tama%C3%B1o%20que%20la%20imagen%2C%20y%20luego%20arrastr%C3%A9%20el%20archivo%20de%20imagen%20al%20centro%20del%20gr%C3%A1fico.%20Despu%C3%A9s%20de%20algunos%20intentos%2C%20la%20alineaci%C3%B3n%20fue%20bastante%20buena.%20(Por%20cierto%2C%20estamos%20trabajando%20para%20mejorar%20esto%20en%20JMP%209.)%20%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-center%22%20style%3D%22width%3A%20474px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Wind%20May31%22%20style%3D%22width%3A%20474px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Wind%20May31%22%20style%3D%22width%3A%20474px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Wind%20May31%22%20style%3D%22width%3A%20474px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F16649i52572759350194FA%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22windmay31.jpeg%22%20alt%3D%22Wind%20May31%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EWind%20May31%3C%2Fspan%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EWind%20May31%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EWind%20May31%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E%20Viento%20may31%20%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3ELa%20gr%C3%A1fica%20muestra%20las%20lecturas%20relativas%20del%20viento%20tomadas%20a%20las%206%20pm%20el%2031%20de%20mayo%20de%202009.%20Con%20la%20ayuda%20de%20la%20imagen%20de%20fondo%2C%20podemos%20ver%20c%C3%B3mo%20var%C3%ADan%20los%20patrones%20de%20viento%20en%20relaci%C3%B3n%20con%20el%20lago%20Michigan.%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EACTUALIZACI%C3%93N%2010%2F6%2F09%3A%20El%20archivo%20de%20datos%2C%20con%20scripts%2C%20ahora%20est%C3%A1%20disponible%20en%20el%20JMP%20%3CA%20href%3D%22http%3A%2F%2Fwww.sas.com%2Fapps%2Fdemosdownloads%2FjmpFileExchange_PROD__sysdep.jsp%3FpackageID%3D000416%26amp%3Bjmpflag%3DY%22%20target%3D%22_blank%22%20rel%3D%22noopener%20noreferrer%22%3E%20Intercambio%20de%20archivos%20%3C%2FA%3E%20.%20Busque%20el%20archivo%20llamado%20%22ChicagoWind.jmp%22%20en%20el%20%3CA%20href%3D%22http%3A%2F%2Fsupport.sas.com%2Fdemosdownloads%2Fsysdep_t4.jsp%3FpackageID%3D000416%26amp%3Bjmpflag%3DY%26amp%3Bsearchvar%3Danalysis%26amp%3Bsearchval%3Ddata%2520visualization%22%20target%3D%22_blank%22%20rel%3D%22noopener%20noreferrer%22%3E%20Secci%C3%B3n%20de%20visualizaci%C3%B3n%20de%20datos%20%3C%2FA%3E%20.%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EFuente%20de%20datos%20e%20imagen%3A%20Laboratorio%20Nacional%20de%20Tormentas%20Severas.%20%3CA%20href%3D%22http%3A%2F%2Fdata.nssl.noaa.gov%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%20Archivos%20hist%C3%B3ricos%20de%20datos%20meteorol%C3%B3gicos%20%3C%2FA%3E%20Norman%2C%20Oklahoma.%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-377894%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%20mode%3D%22NONE%22%20mode%3D%22NONE%22%3ERe%3A%20Gr%C3%A1ficos%20vectoriales%20en%20JMP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-377894%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%20mode%3D%22NONE%22%20mode%3D%22NONE%22%3E%3CP%3EHola%20Xan%2C%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3EMisma%20pregunta%20que%20antes%20de%20RyMcQeN%3B%20%C2%BFC%C3%B3mo%20se%20necesita%20modificar%20el%20script%20para%20agruparlos%20por%20alguna%20otra%20columna%3F%20Mi%20escenario%20es%20de%20la%20industria%20del%20silicio%3B%20Me%20gustar%C3%ADa%20usar%20gr%C3%A1ficos%20vectoriales%20para%20el%20error%20de%20superposici%C3%B3n%20litogr%C3%A1fica%20de%20la%20herramienta%20de%20exposici%C3%B3n%20paso%20a%20paso%20sobre%20la%20oblea%20de%20silicio%20(un%20vector%20por%20esquina%20de%20disparo).%20Mis%20datos%20contienen%20m%C3%BAltiples%20obleas%20y%20estas%20podr%C3%ADan%20usarse%20para%20agrupar.%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3EEn%20el%20generador%20de%20gr%C3%A1ficos%2C%20usar%C3%ADa%20Wrap%20para%20esto.%20Sin%20embargo%2C%20en%20GraphBuilder%2C%20no%20he%20encontrado%20la%20forma%20de%20crear%20vectores%20(estoy%20ejecutando%20JMP15).%3C%2FP%3E%3CDIV%20class%3D%22lia-message-author-rank%20lia-component-author-rank%20lia-component-message-view-widget-author-rank%22%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-380282%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%20mode%3D%22NONE%22%20mode%3D%22NONE%22%3ERe%3A%20Gr%C3%A1ficos%20vectoriales%20en%20JMP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-380282%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%20mode%3D%22NONE%22%20mode%3D%22NONE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F27037%22%20target%3D%22_blank%22%3E%40JanneI%3C%2FA%3E%20%2C%20el%20truco%20aqu%C3%AD%20es%20aplicar%20su%20script%20de%20gr%C3%A1ficos%20de%20personalizaci%C3%B3n%3CEM%3E%20antes%20de%3C%2FEM%3E%20arrastra%20su%20columna%20para%20envolver.%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Graph%20Builder%20Customize%20then%20Wrap.gif%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Graph%20Builder%20Customize%20then%20Wrap.gif%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Graph%20Builder%20Customize%20then%20Wrap.gif%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Graph%20Builder%20Customize%20then%20Wrap.gif%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F32372i5D8280B3952C95AF%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Graph%20Builder%20Customize%20then%20Wrap.gif%22%20alt%3D%22Graph%20Builder%20Customize%20then%20Wrap.gif%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E2%80%83%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-403170%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%20mode%3D%22NONE%22%20mode%3D%22NONE%22%3ERe%3A%20Gr%C3%A1ficos%20vectoriales%20en%20JMP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-403170%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%20mode%3D%22NONE%22%20mode%3D%22NONE%22%3E%3CP%3E%C2%BFC%C3%B3mo%20har%C3%ADa%20para%20trazar%20solo%20vectores%20para%20filas%20que%20no%20est%C3%A1n%20excluidas%3F%20Actualmente%2C%20el%20gr%C3%A1fico%20de%20dispersi%C3%B3n%20no%20mostrar%C3%A1%20las%20filas%20excluidas%2C%20pero%20sus%20flechas%20a%C3%BAn%20est%C3%A1n%20trazadas.%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EEditar%3A%20Ok%2C%20parece%20bastante%20simple%3A%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CPRE%3E%3CCODE%20class%3D%22%20language-jsl%22%3EFor%20Each%20Row(%0A%20%20%20%20If(%20!Excluded()%2C%0A%20%20%20%20%20%20%20%20Arrow(%20%7B%3Ax%2C%20%3Ay%7D%2C%20%7B%3Ax%20%2B%20%3Adx%2C%20%3Ay%20%2B%20%3Ady%7D%20)%0A%20%20%20%20)%0A)%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E
XanGregg
Vector Plots in JMP
Vector plots show arrows on a two-dimensional plot and allow one to see four dimensions of data: x position, y position, arrow angle, and arrow length. Equivalently, the four dimensions can be x start position, y start position, x end position, and y end position. The latter form is most convenient for JMP. Though JMP doesn't have a menu command to create vector plots, arrows can be added to almost any plot without much trouble.
While lots of four-variable data sets can be adapted for vector display, I'll demonstrate with one of the most natural applications: wind data. This data set records wind speed and direction for various weather stations in the Chicago area. I used formulas to convert the speed and direction into end positions for the arrows and then added the following graphics script to a bivariate scatterplot using Customize from the graph's right-click menu.
(view in My Videos)
Bivariate(
	Y( :Lat1 ),
	X( :Lon1 ),
	Show Points( 0 ),
	SendToReport(
		Dispatch( {}, "1", ScaleBox, {Min( -90.9505699180481 )} ),
		Dispatch( {}, "2", ScaleBox, {Min( 38.9936726055607 ), Max( 44.9620694317012 ), Minor Ticks( 0 )} ),
		Dispatch(
			"Bivar Plot",
			FrameBox,
			{Frame Size( 501, 429 ), Add Graphics Script(
				1,
				Description( "Script" ),
				Pen Size( 2 );
				For Each Row( Arrow( {lon1, lat1}, {lon2, lat2} ) );
			), Grid Line Order( 3 ), Reference Line Order( 2 )}
Here's a screen capture showing a little bit of the data table, graph, and customize dialog:WindcaptureWindcapture
The next steps were to delete the rows with no wind and to turn off the points in the graph.
To provide context, I added the map of weather stations provided by the weather service. Placing a image in a graph is a bit tricky (and could be the subject of another post). There are two options: Draw the picture in another custom graphics script, or drag and drop an existing image into the graph. I chose the latter since I had an image file. First, I sized the graph to be the same size as the image, and then I dragged the image file into the center of the graph. After a few tries, the alignment was pretty good. (BTW, we're working on making this better in JMP 9.)Wind May31Wind May31
The plot shows relative wind readings taken at 6 p.m. on May 31, 2009. With the help of the background image, we can see how wind patterns vary in relation to Lake Michigan.
The data file, with scripts, is available in the File ExchangeChicago Wind Data and Plot
Source of data and image: the National Severe Storms Laboratory Historical Weather Data Archives, Norman, Oklahoma.
Last Modified: Mar 18, 2024 12:59 AM
Comments
