JMP Blog
Summer DOE Series: Advanced Topics
JMP continues to push the boundaries of what is possible with DOE in new capabilities and platforms. This session focuses on two of those capabilities: functional DOE and self-validating ensemble models (SVEM). Functional data is two-dimensional data, such as a kinetics curve, heat evolution over time, particle size distribution, or a chemical spectrum. A functional DOE allows you to optimize that entire response curve (instead of a single parameter). Self-validating ensemble models (SVEM) allow you to run even fewer experiments in your design through an advanced modeling algorithms.
Q&A / Discussion
Q: Is functional data analysis in standard JMP?
A: No, functional data analysis is a feature only in JMP Pro.
Q: How do you create a target curve?
A: The target curve can be created based on prior results or a theoretical target that you manually create.
Q: How do you make virtual links between data tables?
A: You can make virtual joins by using Link ID and Link Reference Column Properties.
Last Modified: Sep 7, 2023 9:47 AM
