The AddIn provides a GUI to automatically create normalized columns.
e.g.: weight normalized by weight of a typical 15year old boy/girl.
Open the GUI via Cols/normalize , adjust all settings as you like, then click Apply.
GUI
Details
Columns can be used as:
Settings
The new column can be produced by (just) calculating the values or by generating a Formula Column.
Default setting: Formula which is calculated once and then deactivated.
Add-in developed and tested using the following system configuration:
Developed with JMP 17.1.
Tested with JMP 16-17.2.
This AddIn was triggered by a comment from @mia_stephens in a reply to a Wish List entry:
known restriction:
- subset selection doesn't work for columns with value labels (will be fixed with the next release)
to do:
- add lag option
Hello, this GUI is useful, thank you. Is it possible to add a robust scaler? The most straightforward calculation is to subtract the median and divide by the interquartile range. This should prove robust to outliers.
Great idea -
please follow this link and vote: Add normalization and robust statistical functions (and matrix functions)
Then you get the Option directly via JMP.
For the GUI, I added an Option for IQR and robust normalization (-median & /IQR):
Unfortunately,
it's not possible anymore to post updates for AddIns in the community:
If you are interested in updates, please send me a personal message.
I will also try to publish the latest version of the AddIn via the MarketPlace ...
