This add-in downloads to your menu a JMP Custom Starter Menu created to orient common JMP tools to follow a Six Sigma DMAIC (Define, Measure, Analyze, Improve & Control) flow. Works with releases at least through JMP 14.2.
To see the Master File from which the Add-in Scripts were created, see the following link:
https://community.jmp.com/t5/JMP-Sample-Data/JMP-Custom-Starter-Six-Sigma-DMAIC-Menu-Sample-Data/ta-...
This menu was created with instructions from Brady Brady's article, "Fast and Easy Custom Menus in JMP": https://community.jmp.com/t5/JMP-Add-Ins/Fast-and-Easy-Custom-Menus-in-JMP/ta-p/24054
This add-in was also featured in the recorded JMP Discovery Summit 2016 presentation, "Creating Your Own Dynamic Workflow with JMP Custom Starter Menus": https://community.jmp.com/t5/Discovery-Summit-2016/Creating-Your-Own-Dynamic-Workflow-With-JMP-Custo...
