This add-in provides easy to change X-axis for parallel plot found from Graph Builder which creates one more EDA (Exploratory Data Analysis) tool for JMP which is fairly easy to use and interactive.
ESP also provides supporting analyses, supporting graphs, and some settings user can change to make using the tool a bit simpler such as: hide legend, change Graph Builder size, show proportion of selected in support plots and change support plot types.
User can found different settings, buttons and menus from different location
Empty add-in window with some column selections done
Graphs are created after Update All button is pressed
Selected Columns checked for Disc column types
Selected Columns not checked for Disc column types
I love it! Unfortunatelly it seems to be generated for JMP Pro users
Is there any other similar addinn'S for JMP15 users?
This should function without JMP Pro as it will use Predictor Screening instead of Bootstrap Forest if you don't have JMP Pro.
Quickly unpacking and checking the add-in definitions the minimum version has been defined as JMP16 (I don't remember if there is a reason for this limitation though... but I did develop this on 16 so maybe that is why I left it as 16).
Awesome,very useful
Hi. I want to use this addin to make a Sankey diagram for energy flow of a factor. Is it possible?
To do that, the width on Y-axis should indicate the amount of each flow. May I ask how to adjust the width of each Y-axis factor? An example of the ideal Sankey diagram could be like this: Apple_FY22_NoYOY.width-800.png (800×500)
For something like that I suggest you check out Pictures from the Gallery 8: Innovative Graph Builder Views - (2023-US-30MP-1386) and/orInflow Outflow Parallel Plots - Track Your Budget Flow with JMP Graph Builder
