This is a revision of a tool for working with column names written by @XanGregg
From the original post (link:(
Notes:
2018-08-30: Added a second version of the Addin that accounts for some changes to the Recode Platform in JMP 14.
Thanks Mike, I used this today on some Internet data I imported. Perfect!
-ryan
@XanGregg deserves the credit. I just went in and fixed a couple of things that needed to be changed in the original JSL. Thanks all the same!
Best,
M
How could I get/copy the JSL of recoding column names please? There is a "script" menu but after clicking it I can not see the script anywhere. Thanks in advance
Hi Mike,
I really like your AddIn especially the "recode" option for managing column names. I would like to ask you if you or one of your colleague know about an AddIn that would rename a series of columns based on the names of another series of columns?
Example:
Starting table
| Name | Data1 | Data2 | Data3 |
| AAA | 3 | 4 | 5 |
| BBB | 5 | 6 | 4 |
Intermediate table where 3 columns were added, formulas were entered via Standardize Attributes:
| Name | Data1 | Data2 | Data3 | Column1 | Column2 | Column3 |
| AAA | 3 | 4 | 5 | Log10 (3) | Log10 (4) | Log10 (5) |
| BBB | 5 | 6 | 4 | Log10 (5) | Log10 (6) | Log10 (4) |
Final table (processed by requested AddIn:
| Name | Data1 | Data2 | Data3 | Log10 Data1 | Log10 Data2 | Log10 Data3 |
great help. I was converting the file to excel and then importing using excel import wizard.! This is a big time saver.
