What about changing scale of bin size, adding LSL, USL etc. to each results window?
Two issues:
1. How do I get the sigma value from the histogram I just ploted to the scale bin of the plot?
2. How do I add ref lines with out having counter of the test names?
Thank you very much in advance!
"std"-  is the std value from the statistics table
"???"- is a value from "limits" table.
dt1 = Open();
:result << Set Data Type( Numeric, "Continuous" );
limits = dt1 << Summary( Group( :test_name ), Mean( Eval( "range_min" ) ), Mean( Eval( "range_max" ) ), );
Ntests = N Rows( limits );
vl = V List Box( Text Box( "Spec Limits Script" ) );
dt1 << Distribution(
	Continuous Distribution( Column( :result ), Horizontal Layout( 1 ), Vertical( 0 ) ),
	By( :test_name ),
	SendToReport(
		Dispatch(
			{"result"},
			"1",
			ScaleBox,
			{Min( 97.5173285198556 ), Max( 97.9576714801444 ), Inc( std), Minor Ticks( 0 ),
			Add Ref Line( limits[???,3], "Solid", "Black", "", 1 ), Add Ref Line( limits[???,4], "Solid", "Black", "", 1 )}
