キャンセル
次の結果を表示
表示  限定  | 次の代わりに検索
もしかして:
Israel JMP Users - קבוצת משתמשים - ישראל
This group is open to all JMP users from Israel.
言語を選択 翻訳バーを非表示
eranse
Hebrew in text explorer
Is it possible to use text explorer in Hebrew? would the same rules and techniques apply?
More specifically, can you analyze customer satisfaction  - free text statements with text explorer?
Thanks
Eran
4件の返信4
Re: Hebrew in text explorer
Hi Eran,
as you probably already know, you can easily store Hebrew text information in a JMP data table, since Hebrew is in a Unicode character set and JMP fully supports Unicode: see https://community.jmp.com/t5/JMP-Blog/Welcome-to-the-family-Unicode-lightbulb/ba-p/41851, but JMP Text Explorer is currently supported for the following languages: English, German, Spanish, French, Italian, Chinese and Japanese.
However, you can still analyze text in other languages pretending you are analyzing English text and doing basic stuff like customizing Stop Words and Phrases.
Anyway, what you will miss is all the Stemming functionality, that is an important feature of text exploration: that issue has already been discussed in the Community by a Danish user and solved in the post: https://community.jmp.com/t5/Discussions/Extend-stemming-rules-with-a-new-language/m-p/51714
so I suggest to take a look at the answer and eventually continue that thread.
You can also ask the JMP R&D for a wider support of languages in Text Explorer, by writing a post in the JMP Wish List: https://community.jmp.com/t5/JMP-Wish-List/idb-p/jmp-wish-list
Cheers, Massimo
eranse
Thanks, Massimo
Will follow your advice and see how it goes
Best
Eran
meirav
Visitor
הי ערן
האם היתה התקדמות / למידות לגבי יכולת ניתוח בעיברית? גם אני זקוקה לפיצ'ר הזה נואשות
eranse
הי, לצערי לא.
