Israel JMP Users - קבוצת משתמשים - ישראל
This group is open to all JMP users from Israel.
Idokol
Level II
Efficient formula
Hey,
I have big data table (~30million rows*20 columns) and this Pass/Fail test makes JMP stuck.
The PC is Windows 10 64-bit, i7-4770 @ 3.4Ghz, SSD and 32GB DDR3 1600Mhz.
The JSL is:
cctable << New Column( "New status", Character, Nominal, Formula( If( :result < :L | :result > :H, "Fail", "Pass" ) ) );
Can it be more efficient? Is there's a better choise in JMP to do it?
Thanks,
Ido
4 REPLIES 4
tom_abramov
Level V
Re: Efficient formula
Hi,
Don't use column formulas with such a table.
Try to run a calculation with JSL and paste the results.
Please see attached a table and a script I used.
Regards,
Tom.
Idokol
Level II
Thanks, but the "New Column( ... )" command takes time and everything get's stuck as well.
I will try to use update/join
If you (or anyone else :) ) have a nother idea- I will glad to hear it.
Thanks.
Craige_Hales
My test takes 15 seconds to create the table and 15 seconds to add the extra column. I am using <<runFormulas to make the formula evaluate immediately rather than waiting for idle time.
start = Tick Seconds();
dt = New Table( "Untitled",
	Add Rows( 30e6 ),
	New Column( "L", Numeric, "Continuous", Format( "Best", 12 ), Formula( Random Integer( 1, 9 ) ) ),
	New Column( "result", Numeric, "Continuous", Format( "Best", 12 ), Formula( Random Integer( 1, 9 ) ) ),
	New Column( "H", Numeric, "Continuous", Format( "Best", 12 ), Formula( Random Integer( 1, 9 ) ) )
dt<<runformulas;
stop = Tick Seconds();
Show("create", stop - start, N Rows( dt ) );
dt << New Column( "New status", Character, Nominal, Formula( If( :result < :L | :result > :H, "Fail", "Pass" ) ) );
dt << runformulas;
Show( "add", stop - start, N Rows( dt ) );
"create";
stop - start = 12.8833333333605;
N Rows(dt) = 30000000;
"add";
stop - start = 12.6833333332906;
Formula addedFormula added
Craige
Idokol
Level II
Thanks!
I will do it.
Although what that helped the most was table of 1M * 100 rather then 80M * 5
