Dear members of the community,
i was trying to open the page amazon.co.uk in the following way but without success:
webpage= Load Text File ("https://www.amazon.co.uk");
this is what i get in the log:
JMP could not read all the text in 'www.amazon.co.uk' correctly.
The document might use a text encoding that JMP does not recognize; or JMP might have chosen the wrong encoding (utf-8). Text that JMP could not understand has been removed. The JMP character set preference is set to utf-8.
The location of the first read error is 4 and the byte at that location was 0.
"��t������ ��`��L&��dv'�B^�V��f��
�;�焎�3�=�wEG1E�����p��������!���m��X�f{����$�f���6=�ٓί�g!(j
�ŨI*|T�M�[ٗ�\!"��HA��\��Y�$o������&����P����*K&�;\!"��C��G^b��� E�i J����f:{{�!7(G�A��U���z+�7�D�<�7U�Y
if i attempt the same command with amazon.com all is fine.
i have checked in the html code of the page and it appears to have this about 7 times. so i am assuming it is utf-8
meta charset="utf-8"
also tried to change the preferences Text data file >> Open text file charset >> Best guess but it still doesn't work
would be grateful for any ideas.
