use a value to find the correct column to use in a formula
I have a summary table where I'd like to create a new column 'Rate' with a formula. The column MAXRESULT gives the name of the column I want to use in the formula. unfortunately, I'm getting 'missing arguments' error when I create the formula based on column name.
Column 'Rate' formula:
(100 * Column Name( Parse( "N(" || Char( :MAXRESULT ) || ")" ) )[]) / :N Rows
What's wrong ?
Re: use a value to find the correct column to use in a formula
One option is to use As Column() or Column() instead of Column Name() (with As Column() you shouldn't need []). Also there should be no need to use Parse().
Something like this
(100 * As Column("N(" || Char(:MAXRESULT) || ")")) / :N Rows
Here is an example that shows that @jthi column does work.  I believe that you have an issue with your data.
New Table( "Untitled 12",
	Add Rows( 4 ),
	New Column( "N(1.6)",
		Numeric,
		"Continuous",
		Format( "Best", 12 ),
		Set Values( [445, 446, 0, 0] )
	New Column( "N(1.5)",
		Numeric,
		"Continuous",
		Set Values( [0, 0, 441, 446] )
	New Column( "MAXRESULT",
		Numeric,
		"Continuous",
		Set Values( [1.6, 1.6, 1.5, 1.5] )
	New Column( "N Rows",
		Numeric,
		"Continuous",
		Set Values( [446, 446, 446, 446] )
	New Column( "Rate",
		Numeric,
		"Continuous",
		Formula( (100 * As Column( "N(" || Char( :MAXRESULT ) || ")" )) / :N Rows ),
		Set Selected
Something like this
the proposed formula still doesn't work :(
Error unresolved column
Error Could not find column
anything else I can try out ?
Thanks for your support
	Add Rows( 4 ),
		Numeric,
		"Continuous",
		Numeric,
		"Continuous",
		Numeric,
		"Continuous",
		Numeric,
		"Continuous",
	New Column( "Rate",
		Numeric,
		"Continuous",
		Set Selected
ok it's working on my data set as well.
the strange thing is it's still showing the error in the preview but then when I apply the formula, the result is good.
Thank you all !
Formula editor doesn't like the formula. There are quite a few formulas which can have those red-underlines but they will still work (using Current Data Table() for example). In this case I think it is caused by not evaluation the column names into the formula
