Richardli
unzip + multi file import
Hello
i have few zip files that contain multi .CSV files, would like to perform the below steps
1. allow user to select which zip file to import to JMP
2. list all the .CSV files and allow user to select which files to unzip (use able to select all files or particular files)
3. unzip file
4. import multi .CSV file to JMP under same data table
may I know does JMP is able to support it?
thank you
Craige_Hales
Re: unzip + multi file import
MFI from Selected CSVs in a ZIP , looks generally useful, thanks for asking!
Craige
Richardli
HI : Craige_Hales thank you so much for the sharing, will try it out soon.
