Neo
Neo
Copy values from specific columns of an exiting data-table to another data-table while multiplying selected rows by a constant
I have been able to do the first part (copy) but I am struggling with the second (multiply) part. Any direction is appricated. My example script is below.
bcdt = Open( "$SAMPLE_DATA\Big Class.jmp", invisible ); //load a data-table
myNewdt = New Table( "Parameters Table", //create a new data-table
	Add Rows(8),
	New Column( "Parameter" ),
	New Column( "H", Numeric),
	New Column( "W" ),
Column(myNewdt, "Parameter")[1] = "A";
Column(myNewdt, "Parameter")[2] = "B";
Column(myNewdt, "Parameter")[3] = "C";
Column(myNewdt, "Parameter")[4] = "D";
Column(myNewdt, "Parameter")[5] = "E";
Column(myNewdt, "Parameter")[6] = "F";
Column(myNewdt, "Parameter")[7] = "G";
Column(myNewdt, "Parameter")[8] ="I";
vals = Column(bcdt, "height")[4::11]; //get the values to be copied. Note data type becomes "character"
//show (vals);
For( i = 1, i <= N Items(Vals), i++,  //copy values
	:H[i] =  vals[i]
The above script copies the values in column "height" of data file bcdt to column "H" of another data file myNewdt. However, I want for e.g. the 9th and 10th row entries in column "height" of bcdt  to be multiplied by a constant number, say 0.0001 and pass it on to the same rows (9th & 10th) of column "H" of the other data file myNewdt. The other row values are to be copied unmodified. How to achieve this?
When it's too good to be true, it's neither
Re: Copy values from specific columns of an exiting data-table to another data-table while multiplying selected rows by a constant
Here is the way I would handle this
	Add Rows(8),
	New Column( "W" ),
bcdt:height[9] = bcdt:height[9] * .0001;
bcdt:height[10] = bcdt:height[10] * .0001;
myNewdt:H << set values(vals);
// or
//vals = Column(bcdt, "height")[4::11]; //get the values to be copied. Note data type becomes "character"
//vals[6] = vals[6] * .0001;
//vals[7] = vals[7] * .0001;
//myNewdt:H << set values(vals);
// or
//myNewdt:height[6] = myNewdt:height[6] * .0001;
//myNewdt:height[7] = myNewdt:height[7] * .0001;
frank_wang
Hi Neo
My script as annex. Hope it can help you to sovle the issue.
心若止水
	Add Rows(8),
	New Column( "W" ),
// or
// or
