jasongao
unselected line faded?
How can I make unselected line faded (such as fit line), similar to unselected marker faded?
Jeff_Perkinson
Re: unselected line faded?
What platform are you using?
What version of JMP are you using?
Graph Builder in JMP 14 does that by default.
-Jeff
jasongao
Thanks! Actually, it is for fit lines. For example, in Fit Y by X, after group the data, doing fit lines for each group. How the unselected line be faded?
Jeff_Perkinson
Unfortunately, Fit Y by X doesn't support line selection. What you've selected is only the label in the legend.
Fortunately, as I showed above the same graph can be created in Graph Builder where the line is selectable.
If you'd like for lines to be selectable in the Fit Y by X platform, be sure to enter a suggestion in the JMP Wish List.
-Jeff
jasongao
