vince_faller
transpose list of lists (summarize()) without a for loop
Can anyone think of a way to transpose a list of lists like what comes from the following script so that each row is grouped together instead of by column.
I know I can do it with a for loop but I'm wondering if there's anything better or less brute.
Names default to here(1);
dt = open("$SAMPLE_DATA\Big Class.jmp");
summarize(dt, d = By(:age, :sex));
rows = nitems(d);
cols = nitems(d[1]);
show(rows, cols);
// rows = 2;
// cols = 12;
For this I want to change it from 2 lists of 12 to 12 lists of 2.
Adding a few people that I think might either like this challenge or already have something.
@pmroz,  @Justin_Chilton@gzmorgan0@msharp@ms
Vince Faller - Predictum
11 REPLIES 11
pmroz
Re: transpose list of lists (summarize()) without a for loop
It's not a gold watch but it works.
nrows = nitems(d);
ncols = nitems(d[1]);
show(nrows, ncols);
// nrows = 2;
// ncols = 12;
trans_list = {};
for (i = 1, i <= ncols, i++,
	one_list = {};
	for (k = 1, k <= nrows, k++,
		one_list[k] = d[k][i];
	trans_list[i] = one_list;
show(trans_list);
trans_list = {{"12", "F"}, {"12", "M"}, {"13", "F"}, {"13", "M"}, {"14", "F"}, {"14", "M"}, {"15", "F"}, {"15", "M"}, {"16", "F"}, {"16", "M"}, {"17", "F"}, {"17", "M"}};
vince_faller
I feel like you didn't read the without a for loop part. :p
pmroz
DOH!  I suppose you could write the results to a table, transpose that, and create lists from the table. Might still have a for loop in there though.  Hmmmm...
msharp
PMROZ's nested for loops is probably the best.  If you are looking for alternatives, I can think of two additional ways.
If your data is all numeric you could use matrices which would be pretty slick.  This doesn't have for loops however, the list of lists returned from summarize returns all character values, even for numeric columns.  Which means you would need a nested for loop to convert everything to numbers (if all your data is columns) so that won't be helpful for your problem.
The second option is to convert the list of lists to a data table, transpose that, then turn back.  This requires two for loops for the conversions (I'm not aware of any slick way to convert between nested lists and data tables).  This is probably slower than PMROZ's solution since you have the overhead of creating a data table, however, it's possibly faster for larger datasets.  If you don't actually convert back to a list of lists and just use the transposed data table instead, you could save some time as well.
rows = nitems(d);
show(rows, cols);
//Turn List of Lists into DT ()
dtLL = New Table("Lists of Lists");
for(i=1,i<=nitems(d),i++,
	dtLL << New Column(char(i), Character, Nominal, Values(d[i]));
//Transpose DT
cols = dtLL << Get Column Names;
dtT = dtLL << Transpose(columns(cols));
//Turn back into list of lists
trans_list = {};
for(i=2,i<=ncols(dtT),i++,
	trans_list[i] = column(dtT,i) <<Get Values;
print(trans_list);
//Matrix if all numbers
summarize(dt, d2 = By(:age, :height));
//d2 is all characters...
m = Matrix(d2);
//Example with list of lists of numbers
d2 = {};
d2[1] = As List(dt:height << Get Values);
d2[2] = As List(dt:height << Get Values);
m = Matrix(d2);
mT = Transpose(m);
d2T = As List(mT);
print(d2T);
vince_faller
I found this way but it's slower.  :(
summarize(dt, list = By(:age, :sex));
rows = nitems(list[1]);
cols = nitems(list);
list_flat = parse("{"||substitute(char(list), "}", "", "{", "")||"}");
insert into(list_flat, repeat({"@@@"}, rows));
list_sort = list_flat[	shape(1::rows*(cols+1), cols+1)` ];
remove from(list_sort, -1);
t_list = parse("{"||
	substitute(char(list_sort),
ms
Super User (Alumni) ms
Here's an idea based on Repeat(). A function that essentially is a loop but returns the list directly, without the need to loop any assignments.
In earlier versions of JMP I experienced that Repeat() was way faster than For() in building lists but I think that was "fixed" in JMP 13.
dt = Open("$SAMPLE_DATA\Big Class.jmp");
Summarize(dt, d = By(:age, :sex));
transposed_d = Local({i = 0}, Repeat({i++ ; Eval List({d[1][i], d[2][i]})}, N Items(d[1])));
msharp
Using the new Python hooks in JMP 14 I thought I could cheat.  It mostly works.
Python Init();
ml = Python Execute(
	{d},
	{x, d},
import numpy as np
x = np.transpose(d) # matrix product
print('x=', x)
Show( x, d );
Python Term();
gzmorgan0
//Since column formulas are by row, it uses a built in For Loop this maintains the table values but requires a table....
//This is not a solution for two generic lists
dt << New Column( "Age,Sex", Expression, "None", Formula( Eval List( {:age[Empty()], :sex[Empty()]} ) ), Suppress Eval ); myList= (Associative Array(Column("Age,Sex")) <<get keys);
gzmorgan0
MS, repeat soution is very nice!!
