aadecarlojr
third party reference lookup
I have a genomic locus column and an alleles column for SNP but is there the capability to have JMP use an online SNP reference database to automatically determine the rs number associated with the locus and allelic variation?
Re: third party reference lookup
Hi @aadecarlojr
Unfortunately there is not an automatic lookup function within JMP. You could connect to a database and import an appropriate file and join it into your main table. A custom scripted solution is the only way to make the process more "automatic".
Best,
Chris Kirchberg, M.S.2
Tel: +1-919-531-9927 ▪ Mobile: +1-303-378-7419 ▪ E-mail: [email protected]
www.jmp.com
Hi @aadecarlojr
Best,
www.jmp.com
