Discovery Summit 2026: Early User Edition - September 23-24.Register. It's free.
If you were to add one more item to your list, Where will break. I cannot really understand the error message
Not all sequences are the same size in access or evaluation of 'Where' , Bad Argument(
Print(xs);
xs == [10 20];
), Where/*###*/(Print(xs) ; xs == [10 20])
you won't get back 1, you will get back [1 1] (so one for each match). You should be able to convert this to 1 using All, but Where doesn't like that either (it seems to only compare first item in the matrix?)
xs = {[10 20], [30 20]};
Where(Show(xs == [10 20])); // [1 0] and [0 1]
If you try with xs[1], it will work until you add third item (or remove one) so most likely it is comparing wrong thing
Finally with a lot of trial, error and guess work this worked at least from time to time (not really sure if you want to create large matrices for a mask). This isn't what you would expect from Where() to be for this type of comparisons unless it is documented properly
