The only error I found in your code, is that your closing ")" for your
For( i = 1, i <= N Items( col_lst2 ), i++,
was placed after Bucket 2, instead of after Bucket 3.
I made a couple of additional minor modifications, but the code works as far as I can tell
cdt = Open( "C:\Documents\Data\out.csv" );
Current Data Table( cdt );
sum_lst2 = {};
sum_lst3 = {};
sum_lst4 = {};
col_lst2 = cdt << get column names( Numeric );
colname = Column( col_lst2[i] ) << get name;
If(
Contains(
{"XZ008", "XZ010", "XZ015", "XZ053", "YZ1374", "YZ1375", "YZ9429", "YZ9792", "YZ9908", "YZ1930", "YZ1933", "YZ2744",
"YZ4621", "YZ4625", "YZ4630", "YZ4640", "YZ4681", "YZ4830"},
colname
) | (colname >= "YZ901" & colname <= "YZ916") | (colname >= "YZ954" & colname <= "YZ965") | (colname >= "YZ1360" &
colname <= "YZ1371") | (colname >= "YZ2581" & colname <= "YZ2586") | (colname >= "YZ2900" & colname <= "YZ2950") | (
colname >= "YZ3400" & colname <= "YZ3450"),
Insert Into( sum_lst2, col_lst2[i] )
); //Bucket1
If(
Contains( {"XZ098", "XZ090"}, colname ) | (colname >= "YZ9700" & colname <= "YZ9791") | (colname >= "YZ9793" & colname
<= "YZ9799"),
Insert Into( sum_lst4, col_lst2[i] )
);//Bucket2
If(
!Contains(
{"XZ008", "XZ010", "XZ015", "XZ053", "XZ098", "XZ090", "YZ1374", "YZ1375", "YZ9429", "YZ9792", "YZ9908", "YZ1930",
"YZ1933", "YZ2744", "YZ4621", "YZ4625", "YZ4630", "YZ4640", "YZ4681", "YZ4830"},
colname
colname >= "YZ3400" & colname <= "YZ3450") | (colname >= "YZ9700" & colname <= "YZ9791") | (colname >= "YZ9793" &
colname <= "YZ9799"),
Insert Into( sum_lst3, col_lst2[i] )
); //Bucket3
Eval( Eval Expr( cdt << New Column( "Bucket1", formula( Sum( Expr( sum_lst2 ) ) ) ) ) );
Eval( Eval Expr( cdt << New Column( "Bucket3", formula( Sum( Expr( sum_lst3 ) ) ) ) ) );
Eval( Eval Expr( cdt << New Column( "Bucket2", formula( Sum( Expr( sum_lst4 ) ) ) ) ) );
