TreeStatsNoob
shapiro-wilk test JMP 15
Just updated to JMP 15. When I check for normal distribution, the Anderson-Darling test comes up instead of the Shapiro-Wilk test. I was wondering how i could get the Shapiro-Wilk test back?
Thanks.
stan_koprowski
Re: shapiro-wilk test JMP 15
Hi @AV
You are almost there. As @txnelson stated above.
After you enable the legacy fitters.
Select Continuous Fit and Normal
Once the analysis has been performed got the red triangle next to the Fitted Normal outline and select Goodness of Fit.
Selecting Goodness of FitSelecting Goodness of Fit
This will give you the desired output.
JMP Shapiro-Wilk W TestJMP Shapiro-Wilk W Test
cheers,
Stan
The Shapiro-Wilk test has deemphasized and moved to being a legacy statistic.  To gain access to it, run the Distribution Platform.  Under the red triangle for the Column being analyzed select
     Continuous Fit==>Enable Legacy Fitters
Then go back to the red triangle, and the new selection option will appear
     Legacy Fitters==>Continuous Fit
The Shapiro-Wilk test will be displayed when you select the Goodness of Fit under the Legacy Fitters
AV
AV
Even after enabling the legacy filters and going to
Legacy filters ====> Continuous fit
The Shapiro-Wilk option does not show up and if if you run Normal, the KSL test result is displayed. No other Goodness of Fit option under legacy filters. See attached image. (JMP 15.1.0 Pro)
stan_koprowski
Hi @AV
cheers,
Stan
AV
AV
Thank you very much for your quick reply and screenshots. I had done those steps and it still wouldn't work. I even reset the platform preferences to defaults just in case there was some bug. I was going crazy until I realized my sample was >2000, in which it would default either to the Anderson-Darling test only (through the new fitter, even when legacy fitter had been enabled) or the KSL test (if done via the legacy fitter). If I decrease my sample to below 2000, it works. Thanks again.
I may not have been as precise as I should have been.
  1. Open the Distribution Platform
  2. Select the column(s) you want and press OK
  3. Go to the red triangle next to the name of your column and select                                                   Continuous Fit==>Enable Legacy Fitters                                                           shapiro1.PNG
  4. Go back to the red triangle and select        Continuous Fit==>Fit Normal                   shapiro2.PNG
  5. Go to the red triangle for the Fitted Normal Distribution and select                                                               Goodness of Fit        shapiro3.PNG
AV
AV
