Kip1
setting Graph Builder error bar properties JMP Pro 15.2.1
JMP experts:
Is there a way to set error bar properties in Graph Builder globally? For example, I prefer small end caps on my error bars. It seems one must edit each variable's properties individually which is very tedious work across many variables. I've looked under Preferences>Graph and Style and didn't find anything there.
What's the secret?
Thanks in advance.
gzmorgan0
Re: setting Graph Builder error bar properties JMP Pro 15.2.1
dKip1,
I don't know how to set a global property for error bar end caps.  However, JSL or scripting can make tedious customization easier. Below is a simple example.  JSL can also be used to create an Application or an Add-in that prompts for X, Y, Color etc. variables and applies the favored customizations. In other words, it works as a front-end to getting the inputs and applies the customizations.
obj = Graph Builder(
            Variables( X( :age ), Y( :weight ), Color (:age) ),
            Elements( Bar( X, Y , Legend(5), Error Interval ("Standard Deviation") ) )
frame = Report( obj )[FrameBox( 1 )];  //get a handle for the graph FrameBox
seg = (frame << XPath("//BarSeg"));    //get a handle for the bars
//--- can customize all at once ---/
seg << {Error Bar Cap( "Tiny"), Line Color( "Medium Dark Gray"), Line Width( 2 ) } ;
//--- can customize (set properties) individually ---/
//seg << Set Error Bar Cap( "Tiny");
//seg << Set Line Color( "Medium Dark Gray");
//seg << Set Line Width( 2 ) ;
Kip1
gzmorgan0 Thank you for the reply. Scripting as in your example would certainly do the trick but I failed to mention the problem is with variables grouped on the upper x-axis, not lower. Normally, you can customize error bar features across groups on the lower x-axis via the customization menu. It appears that is what your script is calling for.
DB1
DB1
Black magic, and it worked! In JMP17.2 Pro. Thank you!
Level XIII
"black magic" - or right click/customize:
