This will be a bit slow due to all selections happening
dt << show window(0);
For Each Row(dt,
dt << Clear Select;
dt << Select Rows(Row());
dt << Colors(RGB Color(Eval List({:Red, :Green, :Blue}) / 255));
dt << show window(1);
if more speed is required it could be made faster by selection multiple rows (all rows which have specific color at the same time) or by setting row states.
Summarize(dt, uniq = By(:Color), r = Min(:Red), g = Min(:Green), b = Min(:Blue));
For Each({cur_color, idx}, uniq,
dt << Select Where(:Color == cur_color);
dt << Colors(RGB Color(Eval List({r[idx], g[idx], b[idx]}) / 255));
dt << Clear Select;
Nice picture!
Edit:
Just came to my mind that you could also use Summary table to set the colors
dt_summary = dt << Summary(
Group(:Color),
Mean(:Red),
Mean(:Green),
Mean(:Blue),
Freq("None"),
Weight("None"),
statistics column name format("column")
For Each Row(dt_summary,
dt_summary << Select Rows(Row());
dt_summary << Colors(RGB Color(Eval List({:Red, :Green, :Blue}) / 255));
dt_summary << Clear Select;
Close(dt_summary, no save);
Edit2: One more option looping over the whole table but without selections
For Each Row(dt,
Row State(Row()) = Color State(Eval List({:Red, :Green, :Blue} / 255));
I couldn't figure out how to convert Color State (for example Color State(-15527920)) to number (should be 512.925536155701) so I could have built row state matrix and use << Set Row States.
