PeimeiDa
set row color by given RGB values
Hi, I'm trying to set row color (not cell color) by given RGB values in my columns. However, i can not get the correct loop for assigning the custom colors that I want. Could anyone help?
Code and datatable attached. Thanks!
// Get the current data table
// Initialize the color lists
RedList = Column(dt, "Red") << Get Values;
GreenList = Column(dt, "Green") << Get Values;
BlueList = Column(dt, "Blue") << Get Values;
// Ensure we do not exceed the number of rows or the number of items in any color list
minLength = Min( N Rows(dt), N Items(RedList), N Items(GreenList), N Items(BlueList) );
// Loop to set the row colors
For( i = 1, i <= minLength, i++,
    // Clear any previous selections
    dt << Clear Select;
    // Select the current row
    dt << Select Where( Row() == i );
    // Set the row color
    dt << Set Row Colors( RedList[i], GreenList[i], BlueList[i] );
Re: set row color by given RGB values
This will be a bit slow due to all selections happening
dt << show window(0);
For Each Row(dt,
	dt << Clear Select;
	dt << Select Rows(Row());
	dt << Colors(RGB Color(Eval List({:Red, :Green, :Blue}) / 255));
dt << show window(1);
if more speed is required it could be made faster by selection multiple rows (all rows which have specific color at the same time) or by setting row states.
Summarize(dt, uniq = By(:Color), r = Min(:Red), g = Min(:Green), b = Min(:Blue));
For Each({cur_color, idx}, uniq,
	dt << Select Where(:Color == cur_color);
	dt << Colors(RGB Color(Eval List({r[idx], g[idx], b[idx]}) / 255));
	dt << Clear Select;
Nice picture!
Edit:
Just came to my mind that you could also use Summary table to set the colors
dt_summary = dt << Summary(
	Group(:Color),
	Mean(:Red),
	Mean(:Green),
	Mean(:Blue),
	Freq("None"),
	Weight("None"),
	statistics column name format("column")
For Each Row(dt_summary,
	dt_summary << Select Rows(Row());
	dt_summary << Colors(RGB Color(Eval List({:Red, :Green, :Blue}) / 255));
	dt_summary << Clear Select;
Close(dt_summary, no save);
Edit2: One more option looping over the whole table but without selections
For Each Row(dt,
	Row State(Row()) = Color State(Eval List({:Red, :Green, :Blue} / 255));
I couldn't figure out how to convert Color State (for example Color State(-15527920)) to number (should be 512.925536155701) so I could have built row state matrix and use << Set Row States.
For Each Row(dt,
	dt << Clear Select;
	dt << Clear Select;
Nice picture!
Edit:
	Group(:Color),
	Mean(:Red),
	Mean(:Green),
	Mean(:Blue),
	Freq("None"),
	Weight("None"),
For Each Row(dt,
PeimeiDa
Thanks! These solutions are truely effective, and efficient!
Sorry to dredge up an older post, but I learned something about this just now after struggling for a bit. I was also trying to convert Color States to numbers without success. Instead, I found a way that's even faster as it avoids looping. It feels like cheating, but creating a formula column, then letting JMP use the built-in function to copy those row states was significantly faster than @jthi's previously very fast Edit2 version.
(dt << new column ("Color", formula (color state (RGB color (:R, :G, :B))))) << copy to row states;
2 things
  1. The syntax for setting the color of the row state color was incorrect.
  2. Using the Select Where() made the looping very slow.
Here is my modification
    dt << Clear Select;
    dt << Select rows( i );
    dt << Colors( rgb color(redlist[i],greenlist[i],bluelist[i]) );
