rossmiller
Sort order on JMP graphs?
Is there a way to order elements in a graph?  The attached example includes ranges of years and doesn't look right in an alphabetized order
David_Burnham
Re: Sort order on JMP graphs?
For the column that you use on the x-axis, you can specify the order of the categories by using the VALUE ORDERING property.
Dave
-Dave
David_Burnham
Dave
-Dave
rossmiller
that worked, thanks!
