uwe_hiss
select all items in list box with button?
does anyone know a solution to select all items in a listbox with a [All] button?
New Window( "Select ONE Monthly ", <<Modal,
V List Box(
      Text Box("ALL for Baseline"),
      mon = List Box(:Stage << get values),
      Button Box( "OK", cho = mon << get selected),
dt_data << Select Where(Contains(cho, :Stage));
Regards and thank you in advance,
Uwe
pmroz
Re: select all items in list box with button?
dt_data = Current Data Table();
mon_list = dt_data:Stage << get values;
New Window( "Select ONE Monthly ", << Modal,
     V List Box(
           Text Box( "ALL for Baseline" ),
           mon = List Box(mon_list),
           Button Box( "Select All",
                For( i = 1, i <= N Items( mon_list ), i++,
                     mon << set selected( i )
           Button Box( "OK", cho = mon << get selected ),
dt_data << Select Where( Contains( cho, :Stage ) );
6 REPLIES 6
pmroz
     V List Box(
uwe_hiss
Thanks PMroz ... it works great :)
pmroz
There's a bug in my code if you have duplicates in the Stage column.  A side effect of putting a list into a listbox is that it will only display unique values.
This code will fix that:
Get_unique_values = Function( {in_list}, {Default Local},
    tmp = [=> 0];
    Insert Into( tmp, in_list );
    tmp << get keys;
mon_list = get_unique_values( dt_data:Stage << get values );
    V List Box(
        mon = List Box( mon_list ),
uwe_hiss
Hi Peter,
Thank you for fix it, but I didn't notice this problem or bug.
I have many duplicates in the column Stage, the Listbox displays only unique values.
How can I exclude a certain value like "Baseline"?
At best case, this should not appear in the listbox.
Regards
Uwe
Update:
for (j = N Items (mon_list), j > 0, j--,
if (mon_list == "Baseline",remove from (mon_list, j,1))
pmroz
bindex = contains(mon_list, "Baseline");
if (bindex > 0,
     remove from(mon_list, bindex);
uwe_hiss
Hi Peter,
Thank you for the solutiuon.
Unfortunately it doesn't work for me, maybe it's up to v10
Regards,
Uwe
