StevenC
secondary x axis graph builder
I was wondering if it would be already possible in graph builder to add a secondary X axis in jmp16?
Thanks
SC
SDF1
Re: secondary x axis graph builder
Hi @StevenC
  Yes, you can do it by just dragging the other X variable. Test out the different graphs you can generate depending on where you place the other X variable. I used the Diabetes.jmp file to make the image below.
Hope this helps,
DS
StevenC
Thanks for the info. I was aware of this option but I was actually wondering if a secondary X axis, on top of each other  and not next to each other would already be possible
Steven
